Follow the instructions below to pair your A100 earbuds:
Before Use:
Remove the stickers on the ear buds, before placing the ear buds back in the charging case and closing the lid.
You can pair the A100 to a Bluetooth enabled device by following the steps below:
1. With your A100 in the charging case, press and hold the case function button for 3 seconds until you see the charging case LED (except for the middle LED) flash white.
2. When the left and right LEDs on the A100 charging case are flashing, go to the Bluetooth settings on your device.
3. Select Melomania A100.
4. Your A100 is now paired and connected.
