Once the case has been fully charged, it can provide up to 3 full charges (0-100%) to the earbuds, giving up to 39 hours of total play time, in addition to the charge inside the earbuds.
If you are unsure of how much charge is remaining in your case, you can check the Melomania Connect app, which will show you the battery percentage of the case, as well as both earbuds.
Please note, however, that this time may be reduced by several factors, including:
Ambient Noise Mode:
Enabling noise cancelling will deplete the battery quicker. The A100 can provide up to 11 hours 30 minutes of battery life with ANC disabled, and up to 6 hours 40 minutes of battery life with ANC enabled.
High volume levels:
Using aptX Adaptive or Lossless may deplete the battery quicker, as more data is being transferred between your device and the A100. If you can restrict your device to a lower codec only (AAC or SBC), you may experience longer listening time. Please note that the A100 will automatically use the highest possible codec available, and this can’t be adjusted in the app.
