D/A converters
ESS ES9028Q2M
THD @ 1kHz 0dBFs
< 0.0005 %
THD @ 20kHz 0dBFs
< 0.0005 %
Frequency response
20Hz-20kHz +/- 0.1dB
Signal to noise ratio (REF 1W)
> 120dBr
Crosstalk @ 1kHz
< -120dB
Digital outputs
S/PDIF Coaxial
16/24-bit, 32-192kHz
TOSLINK Optical
16/24-bit, 32-96kHz
AUDIO FORMATS
WAV containing uncompressed, PCM 16-32 bit 32-768kHz, FLAC containing losslessly compressed, PCM 16-32 bit 32-768kHz, Apple Lossless (ALAC) containing losslessly compressed PCM 16-24 bit 32-192kHz, AIFF containing uncompressed, PCM 16-32 bit 32-768kHz, Microsoft® Windows Media TM Audio (WMA 9 Standard) 32-320kbps, MP3 (CBR or VBR) 16-320kbps, AAC, HE AAC and AAC+, (CBR or VBR) 16-320kbps, OGG Vorbis 32-320kbps.
Native DSD64 to DSD512 support.
Streaming protocols
RTSP (Real Time Streaming Protocol), MMS (Microsoft Media Server Protocol), HTTP (Hyper Text Transfer Protocol).
Bluetooth
5.0 A2DP/AVRCP supporting SBC, aptX and aptX HD codecs
Connectivity
UPnP, Local USB media, Airplay , Google Cast , Internet Radio, Spotify Connect, TIDAL, Qobuz, Deezer, Roon Ready.
Playlist
ASX (Microsoft® playlist format) M3U, PLS
Wi-Fi
IEEE 802.11 b/g/n or AC (2.4GHz and 5GHz)
Wi-Fi encryption
WEP, WPA, WPA2
Ethernet
USB
1 x USB 2.0 current limited to 1A
File systems
FAT32, NTFS, Ext4, ExFAT
Mains inlet voltage
100-240 VAC (switch mode) standby consumption
ECO Mode
<0.5W
Network Standby Mode
>2W
Max power consumption
30W
Dimensions
89 x 430 x 325mm (3.5 x 16.9 x 12.8")
Weight
4.15kg (9.1Ibs)
