TV Power Control mode will allow your EXA100 to be turned on and off in sync with your TV, when connected to the eARC input. This feature is enabled by default.
You can enable or disable TV Power Control mode by following the steps below:
- Enter the setup menu - Whilst the EXA100 is in standby mode, press and hold speaker A/B button until speaker A/B white LED’s flash alternately, then release speaker A/B button.
- Select the TV button.
TV LED on (TV LED will be lit blue) – TV Power Control is enabled.
TV LED off – TV Power Control is disabled.
To save the setup settings and exit the setup menu, press the Speaker A/B button.
Pressing the Standby/On button while in the setup menu will exit this setup menu and will not save the setup settings.
