The EXA100 does not feature a dedicated Phono Pre-amp Input. Some modern turntables come with a built-in Phono Pre-amp stage. With the Pre-amp stage enabled on your turntable, you can connect directly to the EXA100's analogue RCA input.
Alternatively, if your turntable doesn't have its own internal Phono Pre-amp, then a separate Phono Pre-amp such as our ALVA Solo Moving Magnet Phono Preamplifier or ALVA Duo Moving Coil & Moving Magnet Phono Preamp would be required.
