You may have noticed that our older legacy apps for Air, Cambridge Connect, and Edge Remote apps are no longer available on the Google Play store. However, you can still download the APK files for these apps, should you need them, below.
You can find helpful instructions on how to install the APKs for these legacy apps here as well as from this article.
If you are using one of the supported devices, we strongly recommend you use the newer StreamMagic app in conjunction with your Network Player which is available to download from the Google Play Store and the Apple Apps Store directly.
Please note: The Air, Cambridge Connect, and Edge Remote apps are no longer supported in terms of updates or bug fixes and as such may suffer from some compatibility and functionality limitations as a result. We are sorry for any inconvenience this may cause.
