HIGH-PERFORMANCE AUDIO MODE - Class A/B amplification
DRIVER - 40mm three-layer composite (PEEK+PU+PEEK)
BATTERY PLAY TIME - up to 100 hrs
BATTERY PLAY TIME (ANC On) - up to 60 hrs
CHARGING TIME - <160 minutes
FAST CHARGE - 5 minutes gives 4 hours playback ANC Off
POWER SUPPLY - USB-C
NOISE ISOLATION - Hybrid ANC
TRANSPARENCY MODE - Yes
MICROPHONES - 5 Mics total
VOICE PROCESSING - 2-Mic Qualcomm® cVc™ Echo Cancelling and Noise Suppression Technology
MELOMANIA APP - No
MELOMANIA CONNECT APP - Yes
VOICE ASSISTANT ACTIVATION - Yes
FIRMWARE UPGRADABLE - Yes - via Melomania Connect
WHAT'S IN THE BOX? - Quick Start Guide, USB-C to USB-C, USB-C to 3.5mm Jack=
BLUETOOTH VERSION - 5.3
TRIPLE-CORE PROCESSOR ARCHITECTURE
- Qualcomm QCC3084, Powerful tri-core processor architecture – supporting complex use cases
- Dual-core application subsystem 32/80 MHz operation
- Single core 240 Mhz configurable Qualcomm® 32‑bit Kalimba audio digital signal processor (or
processing) (DSP) core with flexible clocking from 2 MHz to 240 MHz to enable optimization of performance vs.power consumption - Analog Devices ADAU1787 dedicated low power codec with FastDSP for ANC processing
SUPPORTED PROFILES - A2DP, AVRCP, HSP, HFP
SUPPORTED CODECS - aptX™ Lossless, aptX™ Adaptive, AAC, SBC
WEAR DETECT - Yes
LOW LATENCY - <80ms - Gaming Mode accessible via Melomania Connect
WIND NOISE REDUCTION - Yes
WIRED MODE - USB-C or 3.5mm Jack
GOOGLE FAST PAIR - Yes
ADJUSTABLE EQ - Yes - 7-band adjustable EQ accesible via Melomania Connect
OPERATING TEMPERATURE - 0°C to +40°C
OPERATING RELATIVE HUMIDITY - 10 to 80%, Non-condensing
DIMENSIONS (HEADPHONE) - 250 x 204 x 59mm
WEIGHT (HEADPHONE) - 330g
COLOUR/FINISH (HEADPHONE) - Black, White
