Yes you can use the P100 with a wired connection. The P100 comes with a 3.5mm Jack to USB C cable and a USB C – USB C cable.
Simply connect one of the supplied cables to your compatible device. Some examples of the different uses of each cable can be found below:
Wired Mode (3.5mm Jack to USB C)
Travel: Whilst on an airplane you can either use Bluetooth to listen to your own media or use the supplied cable which will be able to connect to many aircraft in-flight entertainment systems.
Home: If your home Hi-Fi doesn’t have a Bluetooth Output, you can connect the P100 using the supplied
3.5mm - USB-C cable.
Wired Mode (USB C – USB C)
Laptop: Instead of using Bluetooth, or the 3.5mm connection, you can use the supplied USB cable to connect for audio. The audio that comes through the USB cable bypasses the wireless circuitry, so high resolution 24Bit / 96kHz will be supported depending on the audio source.
Mobile: Instead of using Bluetooth, connect the supplied USB-C – USB-C cable from your mobile device to your P100. High resolution 24Bit / 96kHz will be supported depending on the audio source.
