Transparency Mode is a feature which allows you to hear the noises around you without removing your headphones.
The microphones, which are usually used to pick up your voice for a phone call, are repurposed to ensure you never miss a train announcement or continue a conversation without interrupting your music.
You can press the ANC button on the left headphone to cycle through the different Ambient Noise Modes: Normal, Noise Cancelling and Transparency. Alternatively, you can enable Transparency Mode by navigating to the ‘Ambient Noise Control’ option in the Melomania Connect app, and then selecting the circle next to ‘Transparency’.
You will also be able to change the level of Transparency in the Melomania Connect App by selecting ‘Transparency’, where you’ll be able to choose from one of the following Transparency modes: Voice Focus, High and Low.
