You can pair the P100 to a Bluetooth enabled device by following the steps below:
1. Push and hold the Power & Pairing switch on the left headphone all the way up for 3 seconds.
2. The headphone LED will flash white and blue.
3. Open your device Bluetooth settings or follow the Google Fast Pair steps if applicable to your device.
4. Select your headphone model.
5. Your P100 is now paired and connected.
You will also be able to find a pairing guide in the Melomania Connect app.
