Try these solutions:
- Leave the unit for 15 minutes to cool down before pressing the Standby button to resume normal operation
If the unit has not fully cooled down then the temperature may reach the limit soon after the amplifier is powered up.
OVER TEMPERATURE
Over temperature is caused by a combination of high listening levels and low impedance speakers. The Edge M includes temperature detection which constantly monitors the heat generated by the output transistors.
If the monitored temperature reaches a high level (suitably within the limits of the output devices) the amplifier will automatically switch into a fault mode To protect itself from damage.
- Reduce the volume
If distortion is still present, check the speaker connections and impedance ratings.
OVER CURRENT
EDGE M offers V/I (voltage/current) protection by constantly monitoring the output transistors to keep them working inside their Safe Operating Area (SOA). The SOA is a set of limits given by the output transistor manufacturer to ensure reliability. The V/I protection has been incorporated within the amplifier circuitry to provide a fast response to temporary overload conditions. When the V/I protection is triggered the unit will continue to operate but distortion may be heard as the unit protects the output transistors.
- DC
EDGE M offers loudspeaker protection if the output of the amplifier goes to a high constant voltage (DC) because of some internal fault. This is a rare fault, although detecting it will protect your loudspeakers from damage.
Due to the necessary sensitivity of the DC protection circuit, extremely hard clipping of the amplifier may cause DC protection to be triggered. If this fault occurs, please contact your dealer for service or our support team.
