To select the USB Audio input on your CXA80, you will need to press the Bluetooth / USB Audio button found on the front of the unit twice.
* Press the button once to select the Bluetooth input, this will then turn Blue.
* Press the button once again to select the USB Audio input, which will then turn Orange.
Alternatively, you can select this input using by using the USB Audio button on the CX remote.
