1. Check the setting of the internal preamp and ensure that the turntable is connected to the correct amplifier input
2. Check that the record is playing at the correct speed
3. Confirm that your tracking force is set correctly using a stylus force gauge
3i. Match the anti-skate value to this measurement.
4. Check the ground wire connection to be solid if output level switch is set to ‘Phono’
5. Check the condition of the record
6. Check the condition of the stylus
7. Ensure that the turntable is sat level and isn’t picking up external vibrations
