You can assign your favorite radio stations as presets on your Network Player using the StreamMagic app. Using the StreamMagic app will allow you to store and manage up to 99 presets.
1. Go to the 'Radio' tab within the StreamMagic app, and select or search for your desired station
Note: Alternatively, you can select the 'URL' option and type in a radio station's URL.
2. Select your desired radio station, and then select 'Add to Presets'
3. You will then be presented with the option to assign the content to a preset of your choosing. Please select the number you wish to assign to
4. Once the content is assigned to your preset of choice, you will receive confirmation of this
These settings can also be adjusted via the StreamMagic app under the 'Presets' section, where you can remove any unwanted presets.
