Evo 75/150 / CXN100:
Press and hold the Information (i) button on the front panel of the unit, the IP address for your unit will be listed under 'IPv4'.
Edge NQ:
Press and hold the Power button on the front panel of the unit, the IP address for your unit will be listed under 'IP'.
CXN / CXN (V2) / 851N:
Press and hold the Information (i) button on the front panel of the unit, the IP address for your unit will be listed under 'IP'.
CXR120/200:
Using the On Screen Display settings, navigate to the CXR Setup Menu > Network Setup. The IP address for your unit will be listed under 'IP Address'.
AXN10 / MXN10:
Open the StreamMagic app, navigate to Settings > Scroll down to Device information. The IP address for your unit will be listed under 'IP Address'.
