22nd October 2025
General release 139-b-003 is now available for AXN10/MXN10.
- Fixed an issue with 24-bit Spotify Lossless support.
8th October 2025
General release 139-b-002 is now available for AXN10/MXN10.
- Qobuz Connect integration for Gen 4 players.
Bug fixes included in this release:
Track cutoff timing: Resolved an issue where the last track in the playback queue was sometimes cut off prematurely.
Meter display issue: Fixed an issue where the VU and stereo meters did not always respond correctly when playing via USB source.
USB playback skipping: Fixed an issue where skipping tracks during USB playback could cause the player to fast-forward or skip to the next track unexpectedly.
20th August 2025
General release 138-b-013 is now available for AXN10/MXN10.
- You can now save your EQ setup and easily switch between your custom EQ presets whenever you like
- Fixed an issue on the Now Playing screen on some tablet models.
- Fixed stability issues during product setup on Android 7 devices.
- Fixed an issue where preset images did not always load.
- Fixed an issue where the selected preset was not always highlighted after reopening the EQ section.
26th June 2025
General release 138-b-009 is now available for AXN10/MXN10
- Spotify stability improvements
20th May 2025
General release 138-b-007 is now available for AXN10/MXN10
Note: StreamMagic app version 3.1.0 is also required to take advantage of these new features.
Amazon Music Integration
Browse and play your Amazon Music library directly in the StreamMagic app.
Extended Audio Settings
Enjoy more flexibility to adjust your sound preferences with: -
EQ adjustments
Balance control
Room Compensation
- Fixed an issue with scrolling through the library.
- Fixed an issue where AirPlay artwork would not update after the first track.
- Fixed an issue where embedded artwork from USB drives was not displaying correctly.
- Fixed an issue with the 'Sort by' function in album view and within the Favourites section.
- Resolved an issue causing the Android app to unexpectedly return to the main Library screen when the phone locks while browsing a folder.
- Fixed an issue where the "Pair new Bluetooth device" option disappeared after changing the audio output in the Select Output menu.
- Fixed an issue where fast scrolling through long lists in Qobuz, Tidal, or Deezer caused duplicate items to appear at the end of albums, playlists, or tracks.
27th November 2024
General release 136-b-017 is now available for AXN10/MXN10.
- Fixed: Freeze/crash with some internet radio stations
- Fixed: Show correct "Listening on" info when using QPlay
- Added QPlay support
- Fixed: Volume is attenuated when skipping TIDAL and YouTube Music tracks via AirPlay
- Fixed: Recalling UPnP Server (Window Media Player) preset queues tracks but doesn't start playback
- Fixed: Cannot playback Minim Server queue preset
- Update SCD/Cast to latest version
- Fixed: Queue didn’t update on queue screen after adding items
- Fixed: Issues turning on from preset after main power cycle
6th June 2024
General release 134-b-008 is now available for AXN10/MXN10.
- Updated TIDAL Connect
- Updated Spotify
- Updated Roon
- Updated webmin setting page
- Improved Windows Media Player DLNA playback
- Fixed Media Player metadata missing following power cycles
- Fixed no audio after re-connecting to Spotify
- Improved Chromecast setup in foreign languages
- Change "Chromecast built-in" to "Google Cast" and add dark mode logos
- Fix Control4 device discovery
- Fixed Control4 queue management
- Fixed display glitches when playing certain Media Library playlists
- Fixed low sample rate playback on digital inputs
- Improved .WAV file metadata parsing
- Fixed SM App album artwork when playing .M3U playlists
- Added ability to re-order presets
14th February 2024
General release 133-b-013 is now available for AXN10/MXN10.
- Updated to Cast 2.0
- Updated TIDAL Connect (Hi-Res support)
- Updated Spotify Connect
- Fixed digital distortion at the start of playback when streaming AIFF via Minimserver
- Fixed saving single tracks and mixes as presets from the queue
- Fixed metadata handling when skipping tracks during Cast playback
- Improved auto-power-down behaviour
- Improved Bluetooth status messaging
- Implemented embedded album artwork
- Improved Chinese character metadata handling
- Fixed Cast group playback sync
- Added Korean language support
- Improved Bluetooth sender device volume control
26th July 2023
General release 132-b-007 is now available for AXN10/MXN10.
- Enabled pre-amp mode/volume control for the analog outputs
- Fixed re-pairing Bluetooth input with Windows 10 and Linux operating systems
- Improved network connectivity when switching between multiple access points on mesh networks
- Improved playback states when skipping multiple tracks
- Disabled Spotify Normalisation
- Fixed a crash when selecting UPnP track presets after firmware upgrade
- Show the Bluetooth source device name on the "Now Playing" screen
26th April 2023
General release v132-b-004 is now available for AXN10 and MXN10:
- No updates
Known issues:
- Start-up splash screen animation is sometimes cut short by a cold boot.
- Some UPnP track preset recalls can cause the unit to crash after power cycling the unit.
27th March 2023
General release v131-b-003 is now available for AXN10 and MXN10:
- Fixed TIDAL Connect audio dropouts when streaming MQA content to an MQA-enabled DAC via the digital outputs.
- Fixed Webmin "Restart" icon visibility when viewing the Webmin settings page in Dark Mode.
- Fixed French language webmin settings page translations.
23rd February 2023
General release v131-b-002 is now available for AXN10 and MXN10.
