24th September 2025
Early update 139-b-001 is now available for AXN10/MXN10.
- Added support for Qobuz Connect.
4th August 2025
Early update 138-b-013 is now available for AXN10/MXN10.
- Improved display font style and size for better readability from a distance
- You can now save your EQ setup and easily switch between your custom EQ presets whenever you like
- Fixed an issue on the Now Playing screen on some tablet models.
- Fixed stability issues during product setup on Android 7 devices.
- Fixed an issue where preset images did not always load.
- Fixed an issue where the selected preset was not always highlighted after reopening the EQ section.
6th May 2025
Early update 138-b-003 is now available for AXN10.
Early update 138-b-004 is now available for MXN10.
- Improved Audio Settings – a smoother and more intuitive interface
- EQ Toggle – option to disable the EQ completely
- Bug Fixes– better performance and stability
20th March 2025
Early Update 138-b-002 is now available for AXN10/MXN10.
- Add Room compensation feature
- Add 7 band EQ and presets feature
- Add Balance control
- Add Amazon Music service integration
- Update to TIDAL Connect SDK 1.5.0
- Fixed: Unit cannot be factory reset when streaming TIDAL Connect
- Fixed: After 3x fast SM App standby button presses the unit becomes unresponsive and eventually crashes and reboots
18th November 2024
Early Update 136-b-017 is now available for AXN10/MXN10.
- Fix for freeze/crash with some internet radio stations
- Show correct "Listening on" info when using QPlay
5th November 2024
Early Update 136-b-015 is now available for CXN100.
- Added QPlay support
- Fixed: Volume is attenuated when skipping TIDAL and YouTube Music tracks via AirPlay
- Fixed: Recalling UPnP Server (Window Media Player) preset queues tracks but doesn't start playback
- Fixed: Cannot playback Minim Server queue preset
- Update SCD/Cast to latest version
- Fixed: Queue didn’t update on queue screen after adding items
- Fixed: Issues turning on from preset after main power cycle
28th October 2024
Early Update 136-b-013 is now available for AXN10/MXN10.
18th October 2024
Early Update 136-b-012 is now available for AXN10/MXN10.
30th May 2024
Early update 134-b-008 is now available for AXN10/MXN10.
- Avoid random preset 0 appearing
- Change "Chromecast built-in" to "Google Cast" and add dark mode logos
- Fix Control4 device discovery
21st May 2024
Early Update 134-b-006 is now available for AXN10/MXN10.
- Updated TIDAL Connect
- Updated Spotify
- Updated Roon
- Updated webmin setting page
- Improved Windows Media Player DLNA playback
- Fixed Media Player metadata missing following power cycles
- Fixed no audio after re-connecting to Spotify
- Improved Chromecast setup in foreign languages
- Fixed Control4 queue management
- Fixed low sample rate playback on digital inputs
- Improved .WAV file metadata parsing
- Fixed SM App album artwork when playing .M3U playlists
- Added ability to re-order presets
14th February 2024
Early Update 133-b-014 is now available for AXN10/MXN10.
- No notes
22nd January 2024
Early Update 133-b-010 is now available for AXN10/MXN10.
- Updated to Cast 2.0
- Updated TIDAL Connect (Hi-Res support)
- Updated Spotify Connect
- Fixed digital distortion at the start of playback when streaming AIFF via Minimserver
- Fixed saving single tracks and mixes as presets from the queue
- Fixed metadata handling when skipping tracks during Cast playback
- Improved auto-power-down behaviour
- Improved Bluetooth status messaging
- Implemented embedded album artwork
- Improved Chinese character metadata handling
- Fixed Cast group playback sync
- Added Korean language support
- Improved Bluetooth sender device volume control
13th July 2023
Early Update 132-b-007 is now available for AXN10/MXN10.
- Enabled pre-amp mode/volume control for the analog outputs
- Fixed re-pairing Bluetooth input with Windows 10 and Linux operating systems
- Improved network connectivity when switching between multiple access points on mesh networks
- Improved playback states when skipping multiple tracks
- Disabled Spotify Normalisation
- Fixed a crash when selecting UPnP track presets after firmware upgrade
- Show the Bluetooth source device name on the "Now Playing" screen
13th April 2023
Early Update 132-b-004 is now available for AXN10/MXN10.
- No updates
Known issues:
- Start-up splash screen animation cut short from cold boot.
- Some UPnP server preset recalls can cause the unit to crash after upgrading.
(If you have saved any UPnP presets within the StreamMagic app you may need to save these again after updating).
23rd February 2023
Early Update 131-b-003 is now available for AXN10/MXN10.
- Fixed TIDAL Connect audio dropouts when streaming MQA content to an MQA enabled DAC via the digital outputs.
- Fixed Webmin "Restart" icon visibility when viewing the Webmin settings page in Dark Mode.
- Fixed French language webmin settings page translations.
