Up to 4 presets can be stored via the front panel of the AXN/MXN. A preset can be saved directly via the front panel of the unit, by holding down the desired preset number button while playing from the radio station or media you wish to store as a preset.
If the currently playing media can be stored as a preset, holding down one of the preset buttons will save the preset.
Presets can’t be deleted directly from the front panel. To delete a preset, you will need to navigate to the Presets section on the ‘Home’ tab in the StreamMagic app, then select ‘Edit’.
After selecting ‘Edit’ you can remove a preset by tapping the red circle icon and then pressing ‘Delete’ while using an iOS device or by tapping on the station you wish to remove while using an Android device.
