Try this solution
Orient the earbuds so that the microphone is facing towards your mouth
Due to the cylindrical shape of Melomania 1, it may not be obvious that the microphone is facing towards your mouth. This makes a big difference to voice quality.
To ensure the correct orientation, ensure the Cambridge ball logo is upright, with the microphone hole on the bottom facing down.
Do you have the same issue when using the built-in microphone of your device?
Yes or No.
Your issue does not seem to be related to your Melomania earbuds
We recommend checking you have the latest version of the app downloaded on your device. If the problem persists, you should reach out to the app's support team for further guidance.
