Try these solutions:
1. Make sure that the disc is not loaded upside down
2. Make sure that the disc is not too scratched or dirty
3. Check that the disc is compatible
The EVO CD has been designed to only play:
- Compact discs
- Recordable CDs (CD-R)
- Re-writable CDs (CD-RW) bearing the identification logo shown below:
Please note: Any CD-R/CD-RW discs should contain properly recorded Table of contents
It is not possible to play SACD, MP3 or WMA discs on the EVO CD.
4. Make sure that the interconnects are inserted correctly
Please check for any loose, damaged, or otherwise unsecured cables.
5. Ensure that the amplifier is set correctly
Check that the amplifier is set to the correct input, and is actively outputting to the speakers.
