Our range of drivers can be downloaded from our Driver Updates page
| Product | Win 7 or earlier | Win 8,8.1 | Win 10,11 |
| Azur 751R | 1.67 | 5.12.0 | 5.27.0 or newer |
| Azur 751R v2 | 1.67 | 5.12.0 | 5.27.0 or newer |
| Azur 851C | 1.67 | 5.12.0 | 5.27.0 or newer |
| Azur 851D | 1.67 | 5.12.0 | 5.27.0 or newer |
| Azur 851N | 1.67 | 5.12.0 | 5.27.0 or newer |
| CXA61 | Limited support | 5.12.0 | 5.27.0 or newer |
| CXA80 | 1.67 | 5.12.0 | 5.27.0 or newer |
| CXA81 | Limited support | 5.12.0 | 5.27.0 or newer |
| DacMagic 100 | 1.67 | 5.12.0 | 5.27.0 or newer |
| DacMagic 200M | Not supported | 5.12.0 | 5.27.0 or newer |
| DacMagic Plus | 1.67 | 5.12.0 | 5.27.0 or newer |
| DacMagic XS | 1.67 | 5.12.0 | 5.27.0 or newer |
| Edge A | Not supported | 5.12.0 | 5.27.0 or newer |
| Edge NQ | Not supported | 5.12.0 | 5.27.0 or newer |
| Evo 150 | Not supported | 5.12.0 | 5.27.0 or newer |
| StreamMagic 6 | 1.67 | 5.12.0 | 5.27.0 or newer |
| StreamMagic 6 v2 | 1.67 | 5.12.0 | 5.27.0 or newer |
If you own a DacMagic100, or DacMagic Plus, manufactured before 2014 you may need to upgrade its USB first to enable USB Audio 2.0 compatibility.
DRIVER RELEASE NOTES [V5.27.0]
8th December 2021
Fix: Fixed a security vulnerability (update recommended)
New: support for Windows 11 (21H2)
Change: now using SignTools 1.9
- New: support for Windows 10 (21H1)
- New: API version 5.8
- Change: Operating systems Windows 7, Windows 8 and Windows 8.1 are no longer supported (Microsoft discontinued vendor signing)
