No, there is no way to connect a USB drive or HDD directly to the CXA using its ‘USB Audio’ input. The ‘USB Audio’ input on the CXA will only support a direct connection with a PC or Mac. You will, however, be able to use one of our network players in combination with the CXA to do this.
