The C165 speaker grille can be easily removed for painting.
Carefully remove the grille using a small hook, or similar implement placed through one of the grille openings.
Paint the grille using your chosen paint.
3.
If you wish to paint the speaker surround, please use a clear plastic painting mask to cover the speaker cone and avoid causing damage.
