BT100 firmware upgrade:
Driver Updates
Please scroll down on the driver updates support page to find BT100.
Fixes issue when playing Bluetooth audio from some aptX enabled devices.
This affects some(but not all) BT100 units.
The symptom is audio cutting out after 3 minutes of playback with some aptX capable source devices.
If you have any previous version of the update app installed on your PC, you should uninstall this first:
Windows 7 / 8 - ‘Control Panel → Programs and Features’ and double clicking on any installed instance of ‘BT100 Update’.
Windows XP - ‘Control Panel → Add and Remove Programs’ and double clicking on any installed instance of ‘BT100 Update’.
Full instructions from a fresh install are then included in the zip file below; please read them first.
Please note: this upgrade can only be carried out on a Windows computer.
