To disable Fixed Level inputs please follow the steps below:
- Select the input you would like to adjust.
- Hold down the 'menu' button on the front panel to go into the 'config menu'.
- Navigate to the 'fixed input' menu and set turn the volume knob all the way to minimum.
- When minimum volume is reached, the fixed input should click to 'off' and the fixed input should now be disabled.
