Extend and move the aerial until you get the best reception.
AXR100D has an F-type screw connection and the attached aerial can be removed and replaced with an optional outdoor DAB & FM aerial if required.
To remove the aerial:
Feed the supplied aerial key through the aerial.
Turn the key counterclockwise.
