AXC25
D/A Converter: Wolfson Microelectronics WM8524
Filter: 2-pole Butterworth filter
Frequency response (+/-0.4dB): 20Hz - 20kHz
THD @ 1Khz 0dBFs: <0.006%
THD @ 1Khz -10dBFs: <0.015%
S/N ratio, A-weighted: > 93dB
Crosstalk @1kHz: <-95dB
Crosstalk @20kHz: <-95dB
Output impedance: <50 ohms
Gapless Playback: Yes
Maximum power consumption: 15W
Standby power consumption: <0.5W
Dimensions: 75 x 430 x 305mm (3.0 x 16.9 x 12.2”)
Weight: 4.3kg (9.5lbs)
AXC35
Filter: 2 -pole Butterworth filter
THD @ 1Khz -10dBFs: <0.01%
S/N ratio, A weighted: > 95dB
Crosstalk @1kHz: <-98dB
S/PDIF output impedance: <75 ohms
