Important Information:
Do not put anything except for a compact disc into the disc tray as this can damage the mechanism.
Do not force the tray by hand during opening and closing operations.
3.
To avoid dirt and dust entering the mechanism, keep the disc tray closed when not in use.
4.
If the compact disc that you are attempting to load is badly scratched or dirty, the player may be unable to read or play it.
5.
Never attempt to load multiple discs into the disc tray at any time.
1. Using the front panel or remote control, press the ‘Open/Close’ button to open the disc tray
2. Once the disc tray has fully opened, carefully place a disc into the tray with the label side facing upwards
3. Close the disc tray by pressing the ‘Open/Close’ button again
When the tray has fully closed the AXC25/35 will read the disc and display the content information.
4. The disc tray can be opened at any time during playback using either the front panel ‘Open/Close’ button or the one located on the remote control
Only remove an inserted disc after the disc tray has fully opened.
