1. Ensure that the disc is loaded
2. To repeat a specific track, press the Repeat button on the remote
‘RPT ONE’ will appear on the display. Press ‘Play’ and the selected track will now repeat until the function is turned off. Alternatively, press the Repeat button, select the chosen track using the numerical buttons on the remote control and press ‘Play’.
3. Press the Repeat button twice on the remote control
‘RPT ALL’ will appear on the display. Press ‘Play’. The whole disc will now be repeated until the function is turned off.
