What size banana plugs can be used with these speakers? April 01, 2024 11:07 Updated Our speakers use terminals compatible with standard sized 4mm banana plugs. Related articles Which screw is used on the back of the Minx Min22? What size of banana plugs should I use? What are the technical specifications? How do I install the Minx XL? Can I connect banana plugs to the AXA35?
