What’s Included in the Box? April 01, 2024 09:56 1.MIN22 Compact Speaker. 2.Quick Start Guide. 3.Keyhole Bracket. 4.4 x transparent pad Related articles Which screw is used on the back of the Minx Min22? How do I install the Minx MIN22? How can I remove and rotate the grille of my MINX speaker? What are the suggested setups? What are the technical specifications?
