Sensitivity (SPL)
86dB (2.83 Vrms input).
Frequency response
120Hz – 20kHz.
Impedance
8 Ohms compatible.
Recommended amp power
25-200W. Using a high-powered amplifier to lower its volume scale results in lower distortion and better sound. If you hear a distorted sound or mechanical ‘crack’ as the speakers hit their end stops, you are playing the speakers too loud and this may cause damage. With an AVR the Minx C46 speakers should be set to ‘small’ with a crossover frequency of 140Hz. In this configuration, power handling is considerably increased.
Drivers
1 x 2.25”
Speaker dimensions (H x W x D)
98 x ø 88mm (3.8 x ø 3.5”)
Weight
0.46Kg (1.01lbs).
