Skip to main content
No sound through one or both channels
- Check that the amplifier is turned on
- Ensure that the correct input source is selected on the amplifier
- Confirm that all connections between the amplifier and loudspeakers are secure
- Check that the connections between the source equipment and amplifier are secure
- Check the polarity of the loudspeaker connections
- Check that the volume control is set correctly on the amplifier
