Skip to main content
No sound through subwoofer
- Check that the amplifier is turned on
- Ensure that the correct input source is selected on the amplifier
- Check that the subwoofer is turned on
- Confirm that all connections between the amplifier and subwoofer are secure
- Check that the connections between the source equipment and amplifier are secure
- Check that the volume control is set correctly on the amplifier
- Check that the volume control is set correctly on the subwoofer
