Maximum Power Consumption:
10W.
Standby Consumption:
<0.5W.
Mains Inlet Voltage:
100-240V AC.
Gain @ 1kHz:
39dB (Moving Magnet).
60dB (Moving Coil).
Nominal Output:
300mV.
Sensitivity for Nominal Output:
3.35mV (Moving Magnet).
305uV (Moving Coil).
Equivalent Input Noise (A-Weighted):
~0.09uV (Moving Magnet).
~0.08uV (Moving Coil).
RIAA Curve Accuracy:
+/- 0.65dB 30Hz-20kHz.
Signal to Noise Ratio Grounded Inputs ref. 1V Output (20Hz – 20kHz BW).
90dB (Moving Magnet).
70dB (Moving Coil)
THD+N 1kHz (20Hz – 20kHz BW):
<0.0025% (Moving Magnet).
<0.020% (Moving Coil).
Input Impedance:
47k Ohm (Moving Magnet).
100 Ohm (Moving Coil).
Input Capacitance:
100pF.
Overload Margin:
30dB.
Crosstalk @ 20kHz:
85dB (Moving Magnet).
75dB (Moving Coil).
Subsonic Filter Characteristics:
-3dB @ 15Hz 12dB/octave.
Dimensions (H x W x D):
48 x 215 x 159 mm (1.9 x 8.5 x 6.2 “).
Weight:
0.95kg (2.1 lbs).
