The M100 comes with small, medium, and large silicone tips, as well as small and large foam tips. We would recommend trying the full range of tips provided, so you can find the right fit for you.
When trying the foam tips, we would suggest fitting them by following the steps in the image below:
1. Remove the ear tips from your earbuds.
2. Firmly press Memory foam tips onto the soundport. Ensure the tip is secure before use.
3. Once installed, roll the tip between your fingers into a thin, round cylinder.
4. Gently insert the entire ear tip into your ear and hold it in for 10-15 seconds.
