When you purchase the Melomania 1 you will find the following supplied in the box:
- Earbuds (2 pcs)
- Silicone Tips (Original version): Small (2pcs) / Medium (2pcs - attached to Earbuds) / Large (2pcs)
- Silicone Tips (Eco version): Small (4pcs) / Medium (4pcs - attached to Earbuds) / Large (4pcs)
- Memory Foam Tips (Original version): Medium (2pcs)
- Memory Foam Tips (Eco version): Medium (4pcs)
- Charging Case
- Micro-USB Charging Cable (31cm)
- User Manual (EN, FR, DE, IT, SE, Chinese Simplified, Chinese Traditional, JP, KR)
- Great Fit Earbud Fitting Instructions
- Safety Guide
- Feedback/Comment booklet
- Cambridge Audio Stickers & Brand Booklet
If your Melomania 1 box does not contain any of the above please contact us and we can arrange to send out anything that you are missing.
Please note: All Melomania 1 are now packaged in our 'Eco friendly' packaging. This is a mostly brown corrugated cardboard packaging which is fully biodegradable. Even the plastic shrink wrap is made out of corn starch which can be 100% recycled.
