First, make sure that your Garmin watch is equipped with a compatible Bluetooth chip and can indeed connect to Bluetooth headphones.
If this is the case, follow the step-by-step guide to pair your Melomania Touch earbuds with a Garmin Watch.
1. Ensure that your Melomania Touch is fully charged
2. Hold the touch panel on either Melomania Touch Left or Melomania Touch Right for 8 seconds to enable pairing
3. Hold the touchscreen on your Garmin
4. Add your Melomania Touch as a new device
4i. Select Settings → Sensors & Accessories → Add New →
Select Melomania Touch
5. You will hear “Melomania Paired” and “Melomania Connected” voice prompt
6. You may receive a pairing request from a short code (example: 00.1F.F0.13.01). Do not worry if you see this, accept this by selecting the green tick
7. Your Melomania Touch is now connected to your Garmin
7i. You will now be able to play any music you have stored on your Garmin.
After being correctly paired, your earphones should automatically connect to the Garmin when they are removed from their charging case or otherwise powered on.
You will be able to play & pause your music using the Melomania Touch controls. We are, however, aware that it may not be possible to control volume using the touch control on the earphones and therefore must be adjusted using the watch. We apologize for any inconvenience this may cause.
It may be possible to increase your volume but not decrease it.
It may be possible to decrease your volume but not increase.
