HIGH-PERFORMANCE AUDIO MODE - Class A/B amplification
DRIVER - 10mm Driver Recycled Neodymium Magnets
BATTERY PLAY TIME (EARBUDS) - Up to 16 Hours (ANC Off) | Up to 10 Hours (ANC On)
BATTERY PLAY TIME (TOTAL) - Up to 52 Hours (16 + 36) ANC Off | Up to 33 Hours (10 + 23) ANC On
CHARGING TIME - Charging time approx. 150mins (0% to 100%) | Fast Charge: 10 mins charge = 2hrs ANC On | 4hrs ANC Off
WIRELESS CHARGING - Yes - Qi charging
POWER SUPPLY - USB charging (USB-C cable supplied) | Wireless charging
NOISE ISOLATION - Qualcomm™ Adaptive Active Noise Cancelling
TRANSPARENCY MODE - Yes
MICROPHONES - 6 microphones, 3 per earbud
VOICE PROCESSING - 3-microphone Qualcomm® cVc™ Echo Cancelling and Noise Suppression (ECNS)
MELOMANIA CONNECT APP - Compatible
VOICE ASSISTANT - Siri (iOS) / Google Assistant (Android)
IPX RATING - IPX4 water splash resistant
FIRMWARE UPGRADABLE - Yes
BLUETOOTH VERSION - Bluetooth 5.3
TRIPLE-CORE PROCESSOR ARCHITECTURE -
Qualcomm QCC3071, Powerful tri-core processor architecture – supporting complex use cases
Dual core 32-bit processor application subsystem (up to 80MHz)
Single core 240 Mhz configurable Qualcomm®
Kalimba™ DSP audio subsystem
SUPPORTED PROFILES - A2DP, AVRCP, HSP, HFP
SUPPORTED CODECS - SBC, AAC, aptX Lossless™, aptX Adaptive™
WEAR DETECT - Yes
LOW LATENCY - <80ms - Gaming Mode accessible via Melomania Connect
NOISE CANCELLATION - Qualcomm™ Adaptive Active Noise Cancelling
WIND NOISE REDUCTION - Yes
GOOGLE FAST PAIR - Yes
ADJUSTABLE EQ - Yes, 7-band adjustable EQ accessible via Melomania Connect
OPERATING TEMPERATURE - 0°C to +40°C / 32°F - 104°F
OPERATING RELATIVE HUMIDITY - 10 to 80%, Non-condensing
DIMENSIONS EARBUD (W X H X D) – 22 x 19.2 x 23mm
DIMENSIONS CASE (W X H X D) – 44.5 x 80.2 x 27mm
WEIGHT – Earbuds: 6.65g each / 0.235 Ounce | Charging case: 53.3g / 1.880 Ounce | Total: 66.6g / 2.35 Ounce
COLOUR/FINISH (EARBUDS) - Black
COLOUR/FINISH (CASE) - Pantone Black
