Before Use:
Remove the stickers on the ear buds, before placing the ear buds back in the charging case and closing the lid.
You can pair the M100 to a Bluetooth enabled device by following the steps below:
Option 1:
With your M100 in your ears, tap and hold the L or R earphone touch surface for 8 seconds until you hear “Waiting to Pair” and the M100 LEDs flash white and blue.
1. When the LEDs on your M100 are flashing blue and white, go to the Bluetooth settings on your device.
2. Select Melomania M100.
3. Your M100 are now paired and connected.
Option 2:
With your M100 in the charging case, press and hold the case function button for 3 seconds until you see the M100 LED flash white and blue.
