When you purchase the Melomania Touch you will find the following supplied in the box:
2 x Earbuds
1 x Case
1 x USB-A to USB-C charging cable
4 x Small Silicone tips
4 x Medium Silicone tips (2 pre-fitted)
4 x Large Silicone tips
2 x Small Silicone selectable fins
2 x Medium Silicone selectable fins (pre-fitted)
2 x Large Silicone selectable fins
Quick Start Guide (EN, FR, DE, IT, SE, Chinese Simplified, Chinese Traditional, JP, KR)
Melomania Touch Button Press Functions Card
Great Fit Earbud Fitting Instructions
Safety Guide
Feedback/Comment booklet
Cambridge Audio Brand Booklet
If your Melomania Touch box does not contain any of the above please contact us and we can arrange to send out anything that you are missing.
