April 19th 2022
(V2.3.6)
Updates:
After auto power-off the earbud now correctly responds when manually powered on.
When just one earbud is being used it no longer disconnects when reaching 80% battery level.
Touch controls now adjust the volume of videos when using the iOS Photos App.
Touch indication tone is now muted when the touch control for Play/Pause is disabled via the Melomania App.
Earphones now save the volume last set before disconnecting from a device. This was a requested feature from our customers.
48kHz sample rate enabled. Previously disabled due to a bug, since it has now been solved, we can enable this in the firmware.
Improved operation with smart TVs and compatible Bluetooth transmitters. Linked to the 48kHz sample rate enabled.
The aptX codec is now compatible with MacBook. Linked to the 48kHz sample rate enabled.
Voice prompt volume has been reduced. This was a requested feature from our customers.
10th August
(V2.1.9)
Updates:
Balanced EQ preset renamed to Immersive, the EQ curve is unchanged
Bass Boost EQ preset replaced by a new Neutral EQ preset
Improved operation of the app on/off control switches for volume up/down
Improved operation of auto power on/off and the associated LED indication
Volume is now fully muted when the volume is adjusted to the minimum setting
If the earbuds have Transparency on, this is now automatically switched off when the earbuds are replaced in the charging case
Improved volume control with TWS+ phones
Minimized background noise when Transparency is on or during a voice call.
9th August 2021
(V2.1.8)
Updates:
Improvement to Neutral EQ profile
3rd August 2021
(v2.1.7)
**Updates: **
4th April 2021
(v1.4.2)
Updates:
Auto-connect is now quicker, at around 6 seconds.
Optimized power-off consistency when the earphones are placed in the charging case.
Earphones no longer automatically power off after 60 minutes of use on voice calls on a Windows 10 laptop/PC.
The current Audio Mode is now correctly displayed in the Melomania App.
During a system reset, the earphones return to the previous peer connection after 60 seconds, if a new connection is not found.
System reset optimized.
15th March 2021
(v1.3.1)
Updates:
Improved auto power-on reliability when taking earphones out of the charging case.
Improved auto power-off reliability when putting earphones into charging case.
Added “Waiting to pair” voice prompt on removal from charging case after a system reset, or when not previously paired.
Added battery power indication when only one earphone is powered on.
Improved call quality, increasing volume in the receiving device and reducing ambient noise.
Improved volume sync issues on specific Huawei and OnePlus phones.
Auto power-off disabled when transparency is on, and audio play is paused.
System reset no longer resets the voice prompt language to English.
Improved volume balance between left and right stereo channels.
25th January 2021
(v1.2.3)
Updates:
Improved Bluetooth connection stability and pairing.
Improved power management when earbuds are in the charging case, so any abnormal battery discharge is eliminated.
Touch control time increased from 3s to 8s to activate pairing.
15th January 2021
(v1.1.8)
Updates:
Extended the playing time by optimizing charging.
Reduced LED power consumption.
Improved battery charging management.
Fixed battery charge loss from factory.
