Set service order in MacBook preferences
1. Go to System Preferences
2. Select Network
3. At the bottom of the sidebar, select the (...) icon
4. Select Set Service Order
5. Use your mouse to drag Bluetooth PAN to the top
6. Once Bluetooth PAN is on the top of the Service Order list, select ‘OK’
7. Select Apply
A slight delay can be caused by the time it takes for the signal to reach your earbuds
The wireless audio connection creates a slight delay from when audio is played on the device until the audio reaches your speaker. This delay becomes noticeable when playing audio that is part of a video. This is similar to many Bluetooth® speakers and headsets, which means that you may sometimes experience small latency between the video and sound.
