HIGH-PERFORMANCE AUDIO MODE: Yes
DRIVER: 7mm dynamic with Graphene-enhanced diaphragm
BATTERY PLAY TIME (EARBUDS): Earphones up to 9 Hours (Continuous A2DP Playback) *In Low Power mode
BATTERY PLAY TIME (TOTAL): Total up to 50 Hours (9 + 41) *In Low Power mode
CHARGING TIME: approx. 120mins (0% to 100%)
POWER SUPPLY: Power supply 5V, 500 mA (or greater): USB charging (USB-C cable supplied)
DESIGN: Ergonomic, customisable fit
NOISE ISOLATION: Passive noise isolation
TRANSPARENCY MODE Yes
MICROPHONE Qualcomm cVc™ (clear voice capture)
MELOMANIA APP : Compatible
VOICE ASSISTANT ACTIVATION; Siri (iOS) / Google Assistant (Android)
IPX RATING: IPX4 water splash resistant (earbuds & case)
FIRMWARE UPGRADABLE Yes
BLUETOOTH VERSION: Bluetooth 5.0, class 2
TRIPLE-CORE PROCESSOR ARCHITECTURE: Dual-core 32-bit processor application subsystem; Qualcomm QCC3020 Single-core 120Mhz Kalimba DSP audio subsystem
SUPPORTED PROFILES: A2DP, AVRCP, HSP, HFP
SUPPORTED CODECS: aptX™, AAC, SBC
FREQUENCY RESPONSE (EARPHONES): 20Hz – 20kHz
TOTAL HARMONIC DISTORTION: <0.04% @1kHz 1mW
OPERATING TEMPERATURE: 0°C to +40°C / 32°F - 104°F
OPERATING RELATIVE HUMIDITY: 10 to 80%, Non-condensing
DIMENSIONS (CHARGING CASE): 72 x 30 x 44mm / 2.8 x 1.1 x 1.7 inch
DIMENSIONS (EARPHONES): Depth 23mm x Height (earphones without fitting band) 24mm / 0.9 x 0.94 inches
-** WEIGHT**: Earphones: 5.9g each (11.8g both Earbuds) / 0.2 Ounce (0.42 Ounce) Charging case: 56g; Total: 68g / Case 1.97 Ounce. Total 2.4 Ounce -
COLOUR/FINISH (EARPHONES): Black gloss outer surface; White gloss outer surface
COLOUR/FINISH (CASE): Black premium microfibre leather; White premium microfibre leather- (vegan friendly)
