The Melomania Touch reads the pressure you exert on the surface of the earphone using small sensors. As long as you're tapping with enough force in the center of the earphone, you should have no problems at all!
Remember, you can also tap and hold the Right earbud to increase the volume! Holding on the Left earbud will decrease volume.
