Three different silicone find bands are provided with every pair of Melomania Touch. They are packed inside a box under the product inside the main gift box.
Small, medium and large fin bands are provided. Medium fin bands are fitted to your earphones at our factory, however even if these appear to fit, we encourage you to try all three sizes in case an even more optimal fit can be achieved.
Your ears may well be a different size/shape and thus suit two different sizes of fin band. This is quite normal!
The fin bands are marked inside to show if they are for the L or R earbud and if they are S, M or L size.
To remove the bands, just pull the fin at the top and carefully move this away from the main body of the bud.
CAUTION!
When replacing the band, please ensure the top of the band is pointing inwards towards the ear. The notch in the top of the bud and the microphone hole at the bottom should also align with the corresponding parts of the band. This ensures the call quality and Ambient Mode functionality will perform to the highest standard.
