Many issues can be resolved through a factory reset of the earbuds. If you wish to perform a factory reset on your M1+, please follow these steps:
- Place both headphones in the charging case.
- Press and hold both buttons until the earphone LED's flash white.
- Wait for the LED on each Melomania 1+ to blink blue three times.
- The LED will then go back to the “breathing” white display.
- At this point, you can release the buttons as the reset procedure is complete.
- The earphones will no longer remember any of the devices that have previously paired with them.
- When removing either 'Melomania 1+ L' or 'Melomania 1+ R' after a reset, you will hear the voice prompt saying “Waiting to Pair”.
