We don't typically give out service manuals for current products, or products that are still on sale, as these contain detailed component listings and technical schematics which are still our intellectual property. This is standard procedure for most electronic manufacturers.
In warranty:
If your unit is in warranty and experiencing a fault, we would recommend contacting the dealer you purchased it from or the distributor for your region.
Your Cambridge Audio product warranty is the responsibility of the retailer or dealer that you purchased from.
If you purchased from our Cambridge Audio website or via our Amazon or eBay stores, please do get in touch with us directly.
Out of warranty:
If your unit is outside its warranty period and experiencing a fault, we would recommend contacting the dealer you purchased it from or the distributor for your region, as they will be able to advise on the service options available to you.
You can find a list of our distributors below.
