You will be able to shuffle or repeat tracks on the EVO CD in the StreamMagic app. You can do so by following the steps below:
1.) Once you are playing a CD, open the StreamMagic app and select the Now Playing view at the bottom of the screen
2.) Once in the Now Playing view, select the shuffle or repeat button in the bottom left and right hand corner respectively.
3.) You will also be able to view the current queue by swiping left while in the Now Playing view
