1. Connect your EVO CD to your EVO 75/150 using the supplied connection cable.
2. Ensure that your connected EVO 75/150 is running the latest firmware version.
Your EVO 75/150 will need to be running Service Pack version v132-b-004 or later for the EVO CD to function.
3. Turn on the EVO 75/150 and and set the source selector to 'CD'.
4. Using the front panel of the EVO CD or remote control, press the “Open/Close" button to open the disc tray.
5. Once the disc tray has fully opened, carefully place a disc into the tray with the label side facing upwards.
6. Close the disc tray by pressing the “Open/Close" button again. When the tray has fully closed, the EVO CD will read the disc and the EVO 75/150 will display the content information.
7. Press play on the remote control or EVO 75/150 front panel.
